Rebuilding Prins reducer
Re: Rebuilding Prins reducer
#21 Post by LPGC » Sat Jan 28, 2017 11:46 pm
Well, first how much do fuel trims differ on petrol?
If there's a difference between petrol and LPG trims it can be due to multiple factors, such as difference in flow between LPG injectors, lambda probes on way out, differences in compression, valve timing, etc. Or can just be calibration... If trims are closer to zero on petrol would expect calibration to be the case.
