Icom and Led indicator
tgi
#1 Post by tgi » Thu Mar 10, 2016 8:32 pm
My name is Tasos and I want to connect a 12V Led inside the car near the onsole which it will be on when the car is running with LPG instead of Benzin!
Can you tell me the pin of the ICU that give 12 VDC when the ICU turn to lpg???
Thank you
Tasos
rich r
Re: Icom and Led indicator
#2 Post by rich r » Fri Mar 11, 2016 8:20 am
Might be easiest to pick it up from the solenoid feed wire to either the tank or the reducer.
#3 Post by LPGC » Fri Mar 11, 2016 12:31 pm
I'd have said the same Rich.
tgi
#4 Post by tgi » Fri Mar 11, 2016 1:24 pm
Not right...
If I pick up from the solenoid feed wire to either the tank or the reducer the led will on when the engine starts!
I want the led to be on when LPG is running ... not the time while is prepearing to be enable
#5 Post by LPGC » Fri Mar 11, 2016 6:24 pm
There shouldn't be much time between the solenoids turning on and system switching to gas...
What vehicle is this? Does it have pulsed gas injectors or gas distributor?
