lpg waterless system
baz57
#1 Post by baz57 » Fri Feb 19, 2016 11:07 pm
hello everyone I am thinking of using a waterless cooling system put in my car anyone who knows about these systems know of the advantages of having it done :D thing is will it be ok with a lpg system
many thanks
Baz.....
Re: lpg waterless system
#2 Post by Gilbertd » Sat Feb 20, 2016 6:47 am
Do you mean changing for the chemical coolant instead of a water based coolant or do you mean air cooled? If you are talking about the liquid stuff, then it should make no difference.
#3 Post by LPGC » Thu Mar 03, 2016 12:38 pm
With a boiling point of 180c the biggest 'advantage' I can make out would be for dodgy dealers - could allow them to get away with selling a car with blown head gasket, with just a little hole drilled in the expansion tank...
Didn't some early Land Rovers (hot country spec) use oil as coolant?
