a way of raising the height of the access lid by around 12 – 18 inches from ground level
jcurtis
#1 Post by jcurtis » Tue May 14, 2019 11:23 am
Hi, We have a gas tank under our lawn, the lawn slops and we wish to level it off, to do this we need to add additional soil to the area. However, I need to find a way of raising the height of the access lid by around 12 – 18 inches. Is there a product I can purchase similar to a riser uses to raise the height of drain cover or inspection pipes to achieve this desired result?
Re: a way of raising the height of the access lid by around 12 – 18 inches from ground level
#2 Post by Gilbertd » Wed May 15, 2019 11:47 am
A bit of a specialist question that. I would suggest your best bet will be to ask whoever supplies your gas.
