turbo astra new problem oi vey ..
Re: turbo astra new problem oi vey ..
#101 Post by Gilbertd » Sat May 04, 2019 9:29 am
robertXX wrote:
Fri May 03, 2019 8:11 am
power steering fluid do ?
Dunno, but it isn't going to do any harm. ATF seems particularly good at alloy to steel corrosion and mixing it 50/50 with Acetone lets it penetrate more before the Acetone evaporates and leaves the ATF to do it's stuff. A mate had an engine that had been standing for 6 years, outside with no sparkplugs in it so the pistons had corroded into the bores. It had sat for 3 weeks with the bores full of diesel and that made no difference, but leaving it overnight with ATF in the bores and it freed off.
robertXX
#102 Post by robertXX » Sat May 04, 2019 9:35 am
Thanks Gilbert , i used the power steering fluid for a day or two , no change, banged it face down lots and no movement , so am now tying diesel /petrol mix . i think i may have to drill in through from the other side and push it out , then tap an block the hole !
robertXX
#103 Post by robertXX » Sat May 11, 2019 10:38 am
problem solved the Q3 transistor had gone to ground ...replaced that and q9 , all on the flyback circuit , and shes a runner .:)
