Are my calculations correct?
BigM
#1 Post by BigM » Tue Jan 04, 2011 10:06 am
Hi
My way of thinking is if I'm paying 72p per litre for gas, but loosing 20% efficiency compaired to running on petrol then I am running my car as if petrol was currently costing 86.4p per litre (as I'm having to use 20% more fuel to cover the same milage).
i.e 72+20%=86.4
Are my calculations right?
So to travel the same distance would use 20% more gas than petrol.
If my car used 10 litres of petrol to cover 100km then it would use 12 litres of gas.
billynoband
Re: Are my calculations correct?
#2 Post by billynoband » Tue Jan 04, 2011 3:02 pm
Not far off, you may only lose 10%. Depends on the car and the system fitted. You may also need valve saver fluid at 50p per tank.
#3 Post by Gilbertd » Tue Jan 04, 2011 6:52 pm
Blimey, somebody thinking about it logically. I worked out that if petrol stays the same price (around £1.25 a litre even though I saw £1.29 tonight with the extra VAT), gas would need to get to £1.10 a litre before it costs me the same no matter which fuel I run on.
e301988325i
#4 Post by e301988325i » Sun Mar 06, 2011 7:13 pm
BigM wrote:Hi
i.e 72+20%=86.4
If LPG MPG = 80% of Petrol MPG then;
LPG is 80%, to get to 100% would be:
LPG price: divided by 4 x 5, divide by 0.8 x 1.0 or x 1.25 (+25%)
