ML350
ChrisUk01
ML350
#1 Post by ChrisUk01 » Tue Aug 04, 2015 10:03 pm
Not sure if this is the correct place for this post, but has anyone had a Mercedes ML350 converted and if so how many miles do you get on a tank?
I have just got an ML350 and looking to get the conversion done.
Chris
Re: ML350
#2 Post by LPGC » Wed Aug 05, 2015 1:53 pm
I have converted a lot of ML's.
How many miles you get per tank will of course depend on which tank you have fitted and how you drive it. The usual tank option is a cylinder mounted underneath but some owners (where the ML isn't a 7 seater) choose to have a cylinder mounted inside. Where cylinders are mounted inside on MLs there will be a trade off between tank capacity and boot space for the owner to decide on,
Rough figures - Say you get 23mpg on petrol.. so you might get 20mpg on LPG, might fit a 70L tank with net capacity of 56L = 12.3gallions, so giving a range of 246miles and to fill the tank at 50p/L would cost £28. Replace figures with your own - how many mpg do you reckon you are getting on petrol now (subtract say 15%) and what tank will you be having fitted?
One way to look at it is that you'd be saving around £27 every time you fill the LPG tank (based on above figures).
