Landi Renzo gas system
Posted: Tue Dec 05, 2017 11:48 am
by raeturbo
Hi all, it's been a while since I've been here as my Astra is still running fine :)
I have just bought a vauxhall omega 3.2 v6 with a Landirezo gas kit fitted
I need the software and lead (maybe other things I don't know) as I need to
Get into the System to alter the time the gas will come on etc.
Can anyone help me please? Thanks Rae.
Re: Landirezo
Posted: Tue Dec 05, 2017 4:49 pm
by raeturbo
Sorry should, be Landi Renzo
Re: Landi Renzo gas system
Posted: Tue Dec 05, 2017 8:50 pm
by Brian_H
You can pickup the lead either from WTV (http://lpg-kits.com/) or lpg shop (you need 2 leads in their case, http://www.lpgshop.co.uk/base-ccy-usb-l ... to-milano/ and http://www.lpgshop.co.uk/diagnostic-int ... ndi-renzo/). Other places may have it as well, the WTV one comes with the software, not sure on any others.
You'd best check which ecu it is first though, to be sure you can get the software.
The older ones (Omegas for example) won't let you set a switchover below 40 degrees, and some versions of the software will only let you set switchover at 1600rpm (the older version of the same software will let you set it lower though). Also if its cold starting i found you couldn't get it to switch over until it had been running approx a minute on petrol. Warm restarts tended to be a lot quicker.
Posted: Tue Dec 05, 2017 11:20 pm
by raeturbo
Thankyou Brian.
