lpg gauge bottom green light flashing and beeping
superkp
Re: lpg gauge bottom green light flashing and beeping
#81 Post by superkp » Sat Jan 05, 2019 11:39 am
my laptop is older I think at best its usb2 or maybe usb 1.1 . it shows as ..usb serial port (com1) in device manager I have tried using lower com ports, clearing the ports and trying again. I was getting... unable to connect to com port 1 error 5 on various ports.
i tried different software but still no connection.
I will delete all drivers today and do a manual install
#82 Post by Brian_H » Sat Jan 05, 2019 8:33 pm
What version of windows are you using (both main windows version, and is it 64 bit)? Usually usb 3 ports have a blue central bit, though not always the case.
It might help to right click the program your running and select run as administrator if your using windows 10, as error 5 translates to access is denied I think. Given the software doesn't really install it may not have sufficient rights to access the com port, though think its a long shot there.
superkp
#83 Post by superkp » Sat Jan 05, 2019 10:37 pm
its windows 7 32bit usb i.1 or usb2 too old for usb3
I just got a sony laptop with i7 cpu so I assume its got usb 2 or 3 will give it a try in the morning
#84 Post by Brian_H » Sat Jan 05, 2019 11:32 pm
If you open the command prompt, have the interface connected and type the following command into command prompt window what response do you get (doesn't need to be connected to the car when you do this, just plugged into the pc is enough)
Copy con com1
Type in anything here - test will do
Then press ctrl-c on the keyboard
If the port doesn't exist it should give cannot find file specified.
If it does work it should say 1 files copied
If something else is wrong, it should give some idea whats going on.
if its not on com1 currently change the com1 to suit what its currently set to.
superkp
#85 Post by superkp » Sun Jan 06, 2019 8:52 am
hi
I opened command prompt c:\users\user typed Copy con com1 pressed ctrl-c on the keyboard
resulted in c:\users\user appearing below
#86 Post by Brian_H » Sun Jan 06, 2019 10:02 am
Type something into the flashing cursor bit - anything at all doesn't matter what and then press ctrl-c. That should give you some sort of response about either copying files or access denied or similar.
superkp
#87 Post by superkp » Sun Jan 06, 2019 11:26 am
it just takes me back to c:\users\user
#88 Post by Brian_H » Sun Jan 06, 2019 4:05 pm
Don't you get something like the below (the cable i had to hand auto installed on com5, but should illustrate what I mean)?
superkp
#89 Post by superkp » Sun Jan 06, 2019 5:34 pm
on my pc I get exactly the same message as your photo
but my laptop says ….the i/o operation has been aborted because of either a thread exit or an application request 0 files copied
superkp
#90 Post by superkp » Sun Jan 06, 2019 6:00 pm
my other laptop says the same ….the i/o operation has been aborted because of either a thread exit or an application request 0 files copied
#91 Post by Brian_H » Sun Jan 06, 2019 6:40 pm
any different if you use an administrator command prompt? (create a shortcut to cmd.exe and then right click that and choose run as administrator).
superkp
#92 Post by superkp » Sun Jan 06, 2019 7:44 pm
administrator command prompt is same
superkp
#93 Post by superkp » Sun Jan 06, 2019 7:45 pm
difference is my pc is windows 10 both laptops windows 7
superkp
#94 Post by superkp » Sun Jan 06, 2019 7:55 pm
found this but it https://support.solarwinds.com/Success_ ... on_request
when I tried solution it says.. the syntax of the command is incorrect I copied and pasted into command prompt
superkp
#95 Post by superkp » Sun Jan 06, 2019 8:06 pm
because my pc is showing same message in command prompt as brian h
im tempted to move it next to my car to try.
is it likely my laptops are the problem and my pc will weork?
#96 Post by Brian_H » Sun Jan 06, 2019 8:49 pm
Its probabbly just down to the way windows 7 reports it, but thread exit should be down to your pressing ctrl c - do you see 0 files copied or 1 files copied? Your post above says 0, if thats the case i'd suspect something is not right with your interface (all this command is doing is sending your keyboard input to the com port, it doesn't check its been sent anywhere as such, just proves if its possible to write to it - which it should be).
If you plug your usb cable into a different usb port, it might have added another com port rather than using the one you set before - check device manager with the cable plugged into the laptop and see what its set to (or set it to com1) and then try it again - if you get 1 files copied thats a start at least, as it proves the com port does actually work in windows.
#97 Post by Brian_H » Sun Jan 06, 2019 8:52 pm
That solution is for a database - its not relevant to your problem as you don't have that software on your machine. hence the command doesn't work.
superkp
#98 Post by superkp » Sun Jan 06, 2019 9:28 pm
just says 0 files copied
superkp
#99 Post by superkp » Sun Jan 06, 2019 9:35 pm
I notice in you command prompt picture it says 1 files copied on com5 so your computer knows the cable is present
even on my pc it never recognises the cable as it wont copy a file on any com port
#100 Post by Brian_H » Sun Jan 06, 2019 10:00 pm
That does sound to me like something is wrong with either the cable or the drivers. Mine isn't the exact same cable, but should behave in the same way as far as i know (the one i tested with is an ftdi chipset one for KME, FTDI make most of the interface chips for this sort of thing so should be the same).
