lpg gauge bottom green light flashing and beeping
superkp
Re: lpg gauge bottom green light flashing and beeping
#121 Post by superkp » Wed Jan 23, 2019 10:48 pm
I got mixed up my shutoff valve is separate from the reducer. I will check tomorrow find the make and see if it has a adjusting point. I googled a photo of one im assuming if I need to increase pressure I turn the adjuster clock wise
I think my old shutoff valve is where it has a leak, I have a new one that I will fit tomorrow.
#122 Post by Brian_H » Wed Jan 23, 2019 11:18 pm
There is usually a filter in the shutoff valve - it could be a case of replace the filter and o-ring would fix your leak if thats where its leaking, equally could be a bad pipe connection causing it. Depending how its been connected, you might need an olive to replace the one there if it still won't seal and seems to be leaking from the pipe.
On the adjuster, easiest bet is to try adjusting it with the laptop connected and watch which way the pressure moves towards. Don't get too carried away with it though as some will pop out if you go too far.
#123 Post by LPGC » Thu Jan 24, 2019 9:50 am
On the majority of reducer types pressure adjustment is anticlockwise to increase pressure but there are many exceptions.
superkp
#124 Post by superkp » Thu Jan 24, 2019 2:51 pm
hi
I swapped the shutoff and solenoid which stopped the leak. I Checked the reducer(MAGIC III) the Allen key would only move clockwise half a millimetre it will easily go anticlockwise.
I checked the pressure setting and it is now 90/92 bar. Not sure if fixing the leak improved the pressure or turning half mm on the reducer?
I set p work 0.90
p min 0.45
After calibration the p work is now 0.95 and p min is now 0.57 ?
when I set the p work p min do I calibrate or just exit?
on the image showing map settings can I use the up arrow to adjust the map above one?
superkp
#125 Post by superkp » Thu Jan 24, 2019 2:55 pm
LPGC sorry I missed reading your post, I will try in the morning turning the allen key anti clockwise
#126 Post by Brian_H » Thu Jan 24, 2019 4:07 pm
If the leak is on the entry side to the reducer it won't make any difference - its stepping down from approx 8-10 bar when it goes into the reducer, and it can have only been a very small leak.
If you auto calibrate it will wipe out any settings you've changed on that bit, I think Simon was suggesting to just change those settings and exit.
I've not used Esgi, but on some software you have to hit the return key to get it to save a value after entering it as well, else it doesn't save it.
#127 Post by LPGC » Thu Jan 24, 2019 5:33 pm
Anticlockwise increases pressure on Magic3 reducers. Best to talk about degrees of rotation rather than turning X mm, at the lower end of pressure adjustment it can take a full turn of the allen key to make much difference to output pressure. Also check pressure again after a drive that's long enough for the engine and reducer to have been fully warmed for 10 mins as sometimes the pressure drops a little when the reducer is fully warmed up and you don't want much less than 0.9bar when it's fully warmed.
Autocal does change reference pressure with ESGI but you could easily adjust it to 0.9 after autocal (and change p min to 0.45). But if autocal set p work to 0.95 you might as well leave p work as at 0.95... ESGI is much better at compensating for under pressure than it is at compensating for over pressure. Still change p min though.
superkp
#128 Post by superkp » Fri Jan 25, 2019 12:08 pm
HI
ON THE MAGIC3 there are two or I can see two allen key adjusters, you can see one on the pic I posted. I adjusted the one in pic and started to smell gas (I retightened)
I adjusted the other but no change in pressure.
am I adjusting in the right place?
#129 Post by LPGC » Fri Jan 25, 2019 12:36 pm
No you're not adjusting in the right place. You just unscrewed a blanking plug - gas outlets and pressure take-offs can be re-positioned around the circumference of the MJ3 reducer by swapping positions with blanking plugs, there are around 5 blanking plugs around the circumference. Have a better look around it and use a mirror if you have to - there is only one pressure adjusting screw on the majority of reducers including MJ3's, it isn't in a similar position to blanking plugs, it is at the opposite end of the reducer to the gas inlet not on the circumference. If you've previously slackened blanking plugs there's no wonder you could smell gas, make sure they're all quite tight, you don't have to over-do it because they're sealed with little O-rings.
#130 Post by Brian_H » Fri Jan 25, 2019 12:44 pm
Looking at the picture here might help
https://www.lpgshop.co.uk/magic-3-180hp ... 6mm-inlet/
Its at the very top end of that picture right in the middle.
superkp
#131 Post by superkp » Fri Jan 25, 2019 7:04 pm
found it thanks
I adjusted and it hovers between 0.95 & 0.96 or 0.94 & 0.95
I chose the 0.95 0.96
tokk it round the block and it seems better.
I will take it for a proper test tomorrow
#132 Post by LPGC » Fri Jan 25, 2019 8:39 pm
Post some more screen shots? The map's going to need some manual adjustment after autocal anyway.
superkp
#133 Post by superkp » Sun Jan 27, 2019 1:22 pm
HI
I added a screenshot
#134 Post by LPGC » Thu Feb 07, 2019 6:50 pm
@superkp
Interested in selling your broken ESGI ECU?
Had a customer visit for diagnostics on his LPG system (fitted elsewhere) today, symptoms of sometimes beeping instead of switching to gas as though it had run out of gas, sometimes running on gas but poorly. The installer of the system listed the ECU as Stag but it has an ESGI ECU. I diagnosed the problem as broken ECU, on channel 2 it reads either zero ms pinj or very high pinj no in-between, I initially thought the petrol injector break wiring might be wrong (striped and none striped swapped or connected to positive instead of negative) so swapped wiring but the fault remained, petrol injector wiring couldn't be shorted as it ran well on petrol so was looking like the ESGI ECU was broken, to confirm a broken ESGI I swapped petrol break wiring input channels but the fault remained on channel 2 so the ECU is definitely broken. I have a 4 cyl ESGI ECU here but not a 6 cylinder ECU and the owner doesn't want to spend much on fixing it by fitting a new same make ECU or second hand ECU of different make (which would involve a complete re-wire and different map sensor).
So, would be good to get hold of a second hand ESGI 6 cyl ECU. I know yours is broken (relay, but other than the relay it seems to work?), I'd have to wire in a separate system to control the solenoids (or swap relay from his broken ECU to yours, his relay is working). Wouldn't be worth much to him but would buy if price was low enough.
superkp
#135 Post by superkp » Thu Feb 07, 2019 6:58 pm
pay postage and you can have it
#136 Post by LPGC » Thu Feb 07, 2019 8:55 pm
Thanks!
I sent you a PM at the same time as my last post, we could use PMs to discuss how I pay you for postage and where you post it to?
Will want to give you a few bob for your time sending it.
Cheers, Simon
#137 Post by LPGC » Tue Feb 12, 2019 9:57 am
Many thanks to @superkp for sending me his old slightly dodgy ESGI 6 cylinder ECU for free which I received yesterday.
We've swapped a few PMs, I will be paying him for the postage plus a bit on top that he wants to donate to PDSA.
Cheers superkp
Simon.
superkp
#138 Post by superkp » Tue Feb 12, 2019 11:06 am
No problem the PDSA are a good charity
