Smell of gas
robbie1944
Smell of gas
#1 Post by robbie1944 » Thu Dec 06, 2018 7:41 am
My Lexusrx300 occasionally when changing over from a cold engine you can smell gas in the car for a couple of minutes
Most of the time it is fine no smell at all only occasionally any ideas what could be causing this ,oh it has a BRC kit fitted
Bob
hitman
Re: Smell of gas
#2 Post by hitman » Thu Dec 06, 2018 8:09 am
you have a leak somewhere
Re: Smell of gas
#3 Post by Brian_H » Thu Dec 06, 2018 8:59 pm
Have a good look under the bonnet at the hoses from the vapouriser to injectors and manifold, either one has a leak or split or it could do with being done up better. Might help to put some leak detector or soapy water over the joints when its in that state to see if you can find it, but I'd try checking any hose clips are tight first.
