AC Stag 300-6 ISA2 "ecu not supported - code8"
LPGmalta
#1 Post by LPGmalta » Sat Feb 04, 2017 7:10 pm
Hi guys,
i just finished installing a 6 cylinder system on a bmw using ac stag 300-6 isa2 and it is giving me the above mentioned error.
Anyone knows what it could be please?
Re: AC Stag 300-6 ISA2 "ecu not supported - code8"
#2 Post by LPGC » Sat Feb 04, 2017 8:43 pm
Probably using wrong version of software...
LPGmalta
#3 Post by LPGmalta » Wed Feb 15, 2017 10:18 pm
Hi Simon, ended up changing ECU as even with Stag personnel sending me different softwares I couldn't connect.
#4 Post by LPGC » Wed Feb 15, 2017 11:56 pm
Some of the early Stag stuff only works with very early versions of software but that wouldn't apply to any ISA2 ECU. Stag Qbox uses different software again.
I would think it possible to create your problem by uploading incorrect firmware to an ECU, but having said that, Stag has a kind of 'protected mode' for updating firmware and the procedure can sometimes be done even if rest of the software won't talk to the ECU.
At least one firm uses Stag ECUs but with a different sticker on the front and running different firmware, also needs different software. But like the AFC / KME Diego situation, and for that matter all the usual AEB stuff.
It would be a coincidence for someone who doesn't really do many installs to drop on an ECU with a rather unusual problem?
