No BRC system injectors avaialble in the UK? :-(
SteveMJ
#1 Post by SteveMJ » Tue Jan 09, 2018 4:49 pm
I had my LPG system serviced just before Christmas. I mentioned a gas smell and asked the servicing garage (LPG specialist) to investigate.
They identified that 6 (of 8 ) injectors were leaking, the car has done just over 100k miles on LPG and these injectors. All 8 were replaced and I was told these were the last 8 in UK and more would have to come from the Netherlands. Not that mattered at the time as I had all mine replaced.
I could still smell gas and returned to the garage, they identified that two of these new injectors were faulty and would be replaced. Except now there are none available in the UK and will have to wait for a new delivery in this country.
The car runs poorly on LPG now and flags up an engine management fault. I presume that gas is leaking so much that insufficient fuel is being injected into the cylinders.
So, my questions are: Is leaking injectors common? Are replacements often faulty? Is it usual for there to be a lack of spares available?
Thanks for the help.
VXR8 Auto LS3 in Evoke (with LPG)
Re: No BRC system injectors avaialble in the UK? :-(
#2 Post by Brian_H » Tue Jan 09, 2018 5:17 pm
From what others have said (hopefully some will contribute on this point) its not uncommon if they have the BRC lube system where it injects lube fluid into the lpg pipes before the injectors to have problems.
Depends if they were new injectors or used as to if its common to find faulty ones, though if they were the last available they may have been returns.
Tinley Tech are now the official BRC uk distributor since BRCGB went bust. http://tinleytech.co.uk/ It would be worth asking them about availability?
Might help to identify the injectors you require or currently have first (some are better than others) And the ECU in question if you know, as others on here may be able to advise better or alternative injectors. It also might be helpful to findout what the engine management fault is (The petrol ecu will be logging a fault code, knowing what this is might give more of an idea whats wrong?)
#3 Post by Brian_H » Tue Jan 09, 2018 5:21 pm
Also on the leaking (which i missed you saying the first time) it should be fairly easy to find whats leaking - Soapy water should allow you to locate the leak(s) fairly easily. The location may help explain whats failed?
SteveMJ
#4 Post by SteveMJ » Thu Jan 11, 2018 12:34 pm
The garage servicing my LPG system found the leaking injectors and fitted the new ones.
They also identified the leak on two of the replacements. I'm not involved apart from paying and now using petrol all the time until resolved (=more expense).
The injectors were sourced from a company in Cambridgeshire. I'm now waiting to hear when a new delivery is arriving to them so the garage can fit them.
I asked this question as i was surprised that there were no more than 8 injectors in the UK.
Steve
#5 Post by Gilbertd » Thu Jan 11, 2018 1:13 pm
SteveMJ wrote:I asked this question as i was surprised that there were no more than 8 injectors in the UK.
Steve
At 50 quid a pop I doubt there's that much demand for them so Tinley Tech (the new BRC importers and based in Cambridgeshire) are unlikely to keep huge numbers in stock. If they were new, and from TT, and are leaking, then they can be returned as faulty. If you've got two that are currently leaking and 6 of the 8 were leaking before, why didn't they use the two non-leaking ones from the old set?
#6 Post by Brian_H » Thu Jan 11, 2018 9:39 pm
Steve
Theres also a couple of types listed on Tinley Tech's website - We don't know which type he has, or if there is any other types (given the 100k put on them, it may be they are a different type to the ones listed etc, and if no longer fitted to current systems very possible that only a few are kept in stock as you say). But as you say even as a stopgap the old ones would be an improvement over the leaking new ones. IF thats the source of the leak of course.
#7 Post by LPGC » Fri Jan 12, 2018 10:03 am
BRC injectors have a colour coded label, the colour points to the flow rate. For each colour there are a couple of types, one type is held in place on the rail with a circlip (injector has a groove for the circlip), other type is held in place on the rail with a nut (injector has threads). The rail is designed for only one type, so not only do you need to get the colour right you also need to get the type of fitment right unless you want to buy a new rail too (which would then also mean 8 new injectors not just 6). Even changing type of rail isn't always straightforward because depending on what BRC system (electronics) you have the rail may have other fittings where sensors fit.
What colour injectors and type of fitting are yours? Have you asked TinleyTech if they have any?
Did your car run OK before the service? Were the injectors supposedly leaking from the injector body itself (I've seen this on maybe 10 BRC injectors but the most I've seen leak from the body on one vehicle was 2 on a V8), from the seal where they fit on the rail, or were they allowing unmetered gas to flow through them into the engine? In the latter case I wouldn't have expected the car to have driven well on LPG before the service...
I've previously mentioned BRC injectors being damaged on installs with BRC's lube system (of the type which forces lube fluid to flow through them). This can cause injectors to leak unmetered gas into the engine but more often than not just causes them not to meter gas properly (without a leak), which causes drive-ability problems.
It's just about feasible that you could get to the point of having 6 injectors leaking unmetered gas into the engine while the car was still drive-able on LPG but seems very unlikely. Quite a coincidence if 2 out of 6 or 8 newly supplied injectors also leaked (in any way).
Did you get your old leaking injectors back, or did the firm dispose of them for you?
Tinleytech
#8 Post by Tinleytech » Wed Jan 17, 2018 9:12 pm
Just to confirm that the injectors we supplied were most certainly new but were of the older screw fitting type which are now not very common. We are waiting for a delivery of them from BRC in Italy which have been on order since early December, clearly they didn't have stock so must be manufacturing them, normally deliveries are much quicker but some production delay with these (quite common on older parts which are rare)
There are none of these currently available in Europe (that we have found) and believe me, we have looked after being rung nearly every single day about these two.
As an aside, we have never had a faulty new BRC injector (and we have sold an awful lot) but nothing is impossible.
We heard today that the pallets are now on wheels from Italy so should be with us early next week.
Best regards
Tinley Tech.
#9 Post by LPGC » Thu Jan 18, 2018 7:24 pm
Tinleytech wrote: As an aside, we have never had a faulty new BRC injector (and we have sold an awful lot) but nothing is impossible.
I've never seen a faulty new one either.
Pleased TinleyTech are now the suppliers of BRC :-)
SteveMJ
#10 Post by SteveMJ » Sun Feb 04, 2018 6:34 pm
I did get the two injectors replaced. Unfortunately it took a few visits to keep me going.
The injectors cost significantly more than £5, ha ha, at that price I would have saved about £500 and halved the cost of the repair.
I asked for some recompense for the inconvenience and have been told that BRC felt that they did enough to replace the faulty injectors (I am paraphrasing). I was lead to understand they were not interested in keeping their customers satisfied.
I have still asked for something and am awaiting a response.
xtype_lpg
#11 Post by xtype_lpg » Thu Feb 08, 2018 11:22 pm
SteveMJ wrote:I did get the two injectors replaced. Unfortunately it took a few visits to keep me going.
I had some leaking brc injectors last year, solved the leak by fitting injector to a spare rail and pulling a vacuum on the gas inlet, and then feeding some silicone glue around the joint between the metal and plastic seal on the body. the vacume suks the silicone into the leaking gap and seals it. leave for a day and then refit injector, problem solved.
