LPG Tune In South East
EViS
#1 Post by EViS » Thu Jan 15, 2015 9:27 pm
Do any of you serve the South-East? I have an F150 with a Romano system with the following three issues I would like someone to take a look at:
- The EML light is on continuously with both banks showing as too lean;
- After starting, from cold the LPG will switch over from petrol in roughly under a minute. This has been fine until a couple very cold winter's mornings which cause the engine to stall when first started on the driveway. Once moving and stopped at the end of the road/traffic lights, there's no issue;
- The engine idles quite rough on LPG. I've changed the plugs for NGK Iridium and installed new coil boots/springs which has made no difference.
I would like someone reputable to diagnose the above as otherwise the truck seems to drive just fine.
Talkingcars
Re: LPG Tune In South East
#2 Post by Talkingcars » Sun Jan 18, 2015 4:15 pm
Where in the south east are you?
EViS
#3 Post by EViS » Sun Jan 18, 2015 6:13 pm
Surrey.
Talkingcars
#4 Post by Talkingcars » Mon Jan 19, 2015 6:37 pm
Redhill?
Guildford?
Woking?
EViS
#5 Post by EViS » Mon Jan 19, 2015 8:38 pm
They are all fairly local. What are you proposing?
apole
#6 Post by apole » Fri Feb 20, 2015 5:58 pm
BPV in Slough have been very good for me over the years.
Not too far from Redhill, if you avoid the rush hour it won't take long.
Andy
