Gilbertd wrote: Thu Jan 26, 2023 7:26 pm
I'll be interested in how it works (or doesn't).
I'm not sure exactly what I intend to do with the AEB 170. As it stands, it should plug straight into my truck (along with change of stepper) and the engine run - so I have a spare should my AEB 175 ECU or stepper fail. I'll probably get the engine running on it (to further that objective) and maybe drive on it. If it drives better than with the AEB 175 then installing it permanently is the obvious course to take. If not, then hold as a spare or, utilise on the basis it is newer - rather than wait for 20 year old components to fail. For now, getting the petrol system working again is the higher priority.
I found the correct connector on RS so have everything to make up an adapter lead for mine too. My diagnostic cable is different to yours as it just has the 8 way Molex on the end so I need to find out which wire goes to which pin on the Supaseal one.
When I bought my cable it came with the Molex connector (same as yours) and one with the Superseal connector. Are you sure you weren't supplied with both?
In further conversation with WTV-UK, they have supplied both with the AEB cable for 20 years.
They also offer the following:
- !cid_part1_WHE5MbvA_oL3qLDLd@aol.jpg (128.49 KiB) Viewed 4891 times
''If anyone needs the Super-seal plug adapter I can supply it it plugs into there interfaces 8 pin plug 1 = £14.99 including delivery within the UK''
Adaptors available without having to buy the complete lead then.
For anyone constructing a lead with the serial(?) connector on one end and the Superseal on the other, I should be able to provide pin-outs for that.
