PostPosted: Sun Sep 17, 2017 8:33 pm
Hi All
I am having problems with my motorhome. When I connect the fill nozzle gas comes out at pressure. do I need the filler replacing ? I realise I know little about the filling system any advice , help greatly appreciated.
Thanks Guy
PostPosted: Mon Sep 18, 2017 7:26 am
In a word, yes. The back of the pins can wear so the nozzle is not held firmly enough to seal properly. The filler has a non-return valve in it as does the tank inlet so what is escaping is the gas in the hose between the two. See http://tinleytech.co.uk/product-categor ... search=yes for a replacement.
PostPosted: Mon Sep 18, 2017 8:32 am
Thanks for replying yet again Gilbert , I guess replacing will mean cracking the nut and letting the pipe empty them ?
I have single hole tanks with tomasetto valves and as I did not realize there is a none return at that end thought I could end up emptying half a tank on the forecourt !
I appreciate the link.
Guy
PostPosted: Mon Sep 18, 2017 1:26 pm
Yup, only bear in mind that 1 litre of liquid becomes 270 litres of vapour so even a short run of pipe can vent off for quite a while. Make sure you get the correct filler, you've got a choice of standard 8mm olive and nut fittings used if the pipe is rigid copper or plastic or JIC fittings if the pipe is a flexible hose.
PostPosted: Mon Sep 18, 2017 4:12 pm
wow as much as that ! yes its flexi so have ordered that one
Thanks again
Guy
PostPosted: Mon Sep 18, 2017 6:37 pm
Only the other day I was beside a guy at the Shell station at Barnsdale Bar who was filling a motorhome with LPG and had to hold the gun on his filling point to prevent it leaking. I was just giving a vehicle I'd just converted it's first taste of LPG.
Users browsing this forum: Google Adsense [Bot] and 5 guests
