PostPosted: Sun Mar 05, 2017 9:30 pm
Just occurred to me I went the whole of February without posting any conversion pics. and I had intended to start posting more conversion pics. Converted 5 vehicles in Feb including a few Elgrands and fixed a lot more LPG problems on vehicles. Anyway, about this Golf...
Engine bay, all colour coded blue by previous owner. Couldn't resist the blue Vlube fluid for this car :lol:
Tank and filling (adaptor) point. Tank is zero degree due to rear diff under spare wheel area (actually upside down valve'd zero degree). It can easily be lifted to access the battery by undoing the nuts from captive bolts on the brackets - pipes are Faro (so flexible) and long, so tank can be stood on it's end in the boot away from the battery area. Full size adaptor type filling point is hidden behind the rear number plate (owner put plate on hinges but only used sticky pads for the hinges, which came unstuck. He intends to attach hinges with bolts...).
Next conversion a fairly simple BMW 4 cylinder, although it will be what I call semi Valvetronic. Then a Maserati! :mrgreen:
PostPosted: Mon Mar 06, 2017 9:52 pm
This is how I hinged my number plate
http://i169.photobucket.com/albums/u226 ... 5ygywp.jpg
http://i169.photobucket.com/albums/u226 ... qkc7hl.jpg
I'm really pleased with this, and using bits of "rubbish", the hinges are from a broken floor socket and the box for the trailer socket was a broken exterior RCD socket.
(sorry, being a mod I can't post proper photos!)
PostPosted: Tue Mar 07, 2017 7:59 am
Yours all seems to have worked very well, TC!
This should work well when hinges are secured properly - owner attached hinges himself before coming and wants to finish the hinges himself. He trailered the car here, we went for a bit of a test drive when he came to collect but he trailered it away as planned.
PostPosted: Tue Mar 07, 2017 11:39 am
And I was thinking you took February off!
Nice install, the only thing I can see under the bonnet is the lube bottle.
PostPosted: Tue Mar 07, 2017 4:16 pm
And your filler hidden behind the number plate worked great too Simon!
Hehe, February off? No such luck mate :-( :lol:
simon
