Post new topic Reply to topic  [ 177 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 9  Next
PostPosted: Fri Aug 12, 2011 5:36 pm
3.0L V6 AWD Auto GTO, 17MPG or about 50 miles for a tenner.
'Guv
PostPosted: Sat Aug 13, 2011 8:15 pm
Ford Falcon (4.2l 6cyl auto)
about 160-180k (100miles) depending on city or country running, but our gas costs the equivalent of about 40p per litre,
PostPosted: Sun Aug 14, 2011 7:41 pm
http://www.fuelly.com/driver/beeza410/sportage
Not bad, settling down of late, not bad for a 2.7 V6 with Romano system
Kia Sportage V6 Romano + Flashlube
PostPosted: Wed Aug 17, 2011 4:01 pm
20 mpg @ 0.86 a litre,so 51 for a tenner but motor is 1.8 ton v8
PostPosted: Mon Sep 05, 2011 7:08 am
Site Admin
User avatar
300-340 miles from 58l, mixed roads and mixed driving
PostPosted: Wed Sep 07, 2011 5:50 pm
i pay 00.72p PL
65 litres took me 275 miles
can anyone please tell me what sort of MPG this is compared to petrol? I did a rough working of 38-40MPG?
thanks
PostPosted: Wed Sep 07, 2011 5:57 pm
Site Admin
User avatar
thanks
i make it 19
PostPosted: Wed Sep 07, 2011 8:48 pm
sammyv23 wrote:
i pay 00.72p PL
thanks
19.2 mpg (275/65x4.54). However, if you are talking about equivalent cost rather than equivalent mpg, assuming £1.35 per litre for petrol, it works out at the same running cost as if it was doing 36mpg (19.2x1.35/0.72) on petrol.
People quoting equivalent cost mpg rather than actual mpg only goes to confuse people. You'll see adverts for things like a Range Rover V8 with comments like, does 35mpg on gas and the uninitiated think that not only does gas cost less but you use less of it too which isn't the case.
PostPosted: Thu Sep 08, 2011 10:44 am
I have a 4.7 V8 Jeep Grand Cherokee and I get roughly 3.25 mile per litre. The current cost of LPG in my area is about 70p so for a tenner I get roughly 47 miles (approx 14mpg - mainly town/short drives).
Just realised this is my first post (after many months of just viewing and taking in all the info) - Hi everyone.
Kula.
Jeep Grand Cherokee 4.7 V8 Limited XS
Romano RISN LPG
PostPosted: Thu Sep 08, 2011 6:10 pm
just got my jag xj6.
quite disappointed in consumtion!
working out just fuel cost per mile...
LPG = 15p/mile
Petrol = 16-17p/mile
Hardly worth the difference! I pay 74p for lpg, and 130p for unleaded.
PostPosted: Thu Sep 08, 2011 8:50 pm
It's poorly......
PostPosted: Fri Sep 09, 2011 10:37 am
LPG = 15p/mile
I make that 22mpg on gas (which doesn't sound surprising), 35-37mpg on petrol (which sounds rather good!) What engine does it have?
As you've just got it, and presumably been running on LPG most of the time, to get accurate mpg figures on petrol it may be an idea to brim the petrol tank a few more times (if you can afford it!) in case the petrol pump cut off was more sensitive from one fill to the next.
PostPosted: Mon Sep 12, 2011 8:00 pm
well im going to run on petrol full tank this week to get a true comparison.
but with the 3.0litre engine i reckon the price of lpg now means it just isnt worth the hassle.
it does roughly 19-20mpg just lpg which is about right. unless you can get lpg for unduer 65p or something how can that be exciting! my old 2.7l diesel merc did almost 50mpg - but that was a disappointing car to own. but one tank could take me 650 miles or more!
and with lpg i need to fill up every 2 days - bit of a pain really. i should have done more research frankly. no website really tells you the full picture.
i know autogas farms do cheaper lpg but no where near one here nr london unless someone knows better.
PostPosted: Tue Sep 13, 2011 12:47 am
So you've ruled out the possibility that the LPG system is neglected or otherwise poorly, then?
PostPosted: Tue Sep 13, 2011 6:20 am
Assuming the X300, 3.0 litre V6, XJ6, Parkers reviews reckon it should do 27 mpg on petrol so you LPG figure should be around 22 mpg. How are you getting the petrol figures which do seem wrong unless you are driving it extremely economically. If you are getting these figures from the computer, that confirms that the gas system is out of tune as it is causing the petrol ECU to lower the petrol injector times to compensate for the gas tune.
The 3.0 litre XJ6 isn't particularly economical at the best of times, the engine is underpowered for the car. A friend runs the supercharged 4.2 litre V8 version on gas and gets a consistent 19 mpg on LPG which compares with the quoted petrol figure of 23 mpg. He's got a 100 litre tank installed and has a range of well over 300 miles.
PostPosted: Tue Sep 13, 2011 9:21 am
Ooh, I don't think thats entirely fair ... the V6 should be in an all-ally car (X350) I found it lively enough, though its not as 'relaxed' an engine as the old 3.2 V8
jagman:
It is true you can't get a big tank in an XJ6/8 without seriously compromising the already limited boot space, it's a nuisance but that's a quality of the XJ not LPG in general. The original install customer made that size choice for you.
I think at the root of the complaint here is the reportedly high petrol mpg, which as you've probably gathered no-one quite believes.
PostPosted: Tue Sep 13, 2011 10:29 am
If it's truly costing 16-17 pence per mile whilst on LPG, I would be very happy with that personally, considering I pay 16 pence per mile on a 1.9 diesel car averaging 40+mpg!
PostPosted: Tue Sep 13, 2011 5:48 pm
mat_fenwick wrote:
... I pay 16 pence per mile on a 1.9 diesel car averaging 40+mpg!
Not nearly as soothing as swanning around in an XJ, either ;)
PostPosted: Sun Oct 02, 2011 9:36 pm
1988 BMW 325i M20 2dr 21-22mpg on gas (economy not considered when driving best 28mpg)
2002 BMW 330i M54 estate 23-24mpg on gas - (driven smoothly albeit faster than most)
250 miles from both, toroidal tanks in the wheel well.
PostPosted: Tue Oct 25, 2011 7:41 am
If you on KM like me here is copy and paste.
Quote:
Motor size-
Fuel injection/Carburetor-
Open loop/closed loop system-
Highway usage Km/Ltr-
Around town usage Km/Ltr-
Average usage Km/Ltr-
