 Post subject: CNG?
PostPosted: Wed Nov 25, 2009 12:55 am
I noticed the other day that there is a garage near me selling CNG. The garage mainly caters for trucks and the CNG is probably also for trucks or busses?
Anyway, it's currently at 27p/litre, so I started wondering if it's possible to use CNG on an LPG conversion, as it's essentially the same idea?
I know when natural gas came out years ago, people had to change the burners on all their hobs, but as the way the fuel is burnt in an engine is different, I wondered if there would be similar issues with CNG/LPG?
The manual for the Zavoli kit on my sisters Astra shows various gauge set ups for CNG.
So, can CNG be used on an LPG setup, or would changes need to be made?
 Post subject:
PostPosted: Sat Nov 28, 2009 2:26 pm
Did you notice what sort of nozzel was used for re-fueling? Was it like a LPG baynot fitting?
Jon.
 Post subject:
PostPosted: Sat Nov 28, 2009 8:59 pm
User avatar
Quote:
CNG is made by compressing natural gas (which is mainly composed of methane [CH4]), to less than 1% of its volume at standard atmospheric pressure. It is stored and distributed in hard containers, at a normal pressure of 200–220 bar (2900–3200 psi), usually in cylindrical or spherical shapes.
I think there would be some major reworking needed to convert an LPG setup to CNG .... I suspect the tanks are different, the filler will be different, you'd have to take the vapouriser out and fit some sort of pressure reducing valve.
Quote:
CNG's volumetric energy density is estimated to be 42% of LNG's (because it is not liquefied), and 25% of diesel's.
For the same quantity you'd get less than 1/2 the range so the cost/per mile would be not far off the same ...
Now these are just my initial thoughts .. and probably wrong !!!! :)
 Post subject:
PostPosted: Fri Dec 04, 2009 10:43 am
pressure on cng is far higher than on lpg, I have a pdf somewhere from opel showing the install on a Zafira. They have to have massive tanks so a custom multi tank setup is put in place of your original fuel tank and a tiny petrol tank is installed
I asked my installer whether he could fit that tank setup to my zafira and he said it was too much work with the valving and certification
 Post subject:
PostPosted: Sun Dec 06, 2009 6:31 pm
Some information on CNG for road vehicles:
The cylinders needed are much heavier, as CNG working pressure is up to 200 bar. Pipework is much heavier too (usually 2mm wall stainless pipe).
As you already have a gas, there is no need for a vapouriser, but instead a pressure reducing valve. Thereafter, you can (like LPG) use either a mixing ring or a gas injection system.
The "essentials" of the system are very similar to LPG, but (other than the mixing ring) are all quite different in their construction.
Also, the "energy density" of CNG is nowhere near as high as LPG (9 mJ/cylinder litre as opposed to 25mJ/cylinder litre for LPG)
To the OP: where was this CNG filling station, and are you sure it was a price per Litre, and not a price per kg? CNG is generally sold by the kg.
 Post subject:
PostPosted: Sun Dec 06, 2009 11:39 pm
Thanks to everyone for the info....
Sounds like CNG is a no-goer for the time being then!!
The place selling CNG is on the A460 (Cannock Road) near Shareshill. I'll have to check next time I'm passing if the price was per litre or per Kg.
Guess I'll stick to good ole LPG for now!!!
 Post subject:
PostPosted: Mon Dec 07, 2009 9:03 am
I think the kindest thing to say about CNG is that it is currently where LPG was about 20-25 years ago:
- expensive to do the vehicle conversion
- no specialists available
- kits have to be imported
- very limited number of filling stations
- only really useful for fleet operators with their own filling facilities
With the very real difference that CNG is currently more expensive than LPG, so commercially it makes no sense, and hence there will be little or no market development of it.
Which is a bit of a shame, as it's RON is about 130, and so if you set up a turbocharged engine to use it, you can run absurd turbo pressures and get a remarkable amount of power from it! Even in a naturally aspirated engine you can run with compression ratios up to 15:1 and get very good thermal efficiency.
 Post subject: CNG
PostPosted: Tue Mar 23, 2010 8:59 am
... but the absolute beauty of CNG is that it can be created from waste products not fossil fuel, and it's not just a carrier of energy like the hydrogen option. So.... create your methane from waste food or spent products (eg. from the dairy industry or sewage works), via anaerobic digestion, mess about with it a bit (compress & clean) to get a pure fuel, bottle it & sell. See organic-power & environment-agency.gov.uk/business/sectors
Meanwhile convert your vehicle, chilterngascars or greenconversions
or buy one greencarsite.co.uk/GREENCARS/Volvo-S60-CNG-Biofuel
.... Get a tank in your drive, fill it with methane-from-waste, add a vehicle filling system, eg. gasfill & voila, extremely low-carbon transport. Now I have to put my money where my mouth is! :P
The real attraction of this is that you can also use the gas to fuel your house boiler, almost-carbon-free home & transport :D
PS. why are links switched off? It took me ages to insert them then I had to strip all the useful info!
 Post subject: Re: CNG?
PostPosted: Thu Nov 18, 2010 3:38 pm
Can you tell me please where the CNG station is?
Colin
PostPosted: Thu Nov 18, 2010 10:04 pm
Or where it was a year ago when this was posted..... I doubt the price is the same now.
PostPosted: Sun Oct 21, 2012 8:24 am
There is very littel in terms of CNG filling stations in the UK. One in Nottingham ( I think) and one confirmed in Crewe. A whisper about oen proposed in Lincoln. Councils in Wiltshire I think run the Mayor's car on it. The trucks use LNG, not the same. There is an LNG network run by Chive. LNG is of no use for CNG powered vehicles. What one poster in theis threaed saw at 27p was LNG.
I have a CNG Volvo V70.
