Post new topic Reply to topic  [ 25 posts ]  Go to page Previous  1, 2
PostPosted: Mon Dec 02, 2013 1:09 am
Pipeclips, a soldering iron and some heatshrink would be a good start......
PostPosted: Mon Dec 02, 2013 11:31 pm
Lexus came into today. Nice how all the pipes are hovering just over the exhaust manifold and the liquid fill pipe is only 2 inches away from the manifold with no heat shield.
Just waiting to find out who chucked it in and put the car on the register.
PostPosted: Tue Dec 03, 2013 12:08 am
Is that ECU just wedged in under the wiring conduit? There doesn't appear to be any screws in the mounting holes and there's not even one of the bodgers favourite, the tie wrap!
PostPosted: Tue Dec 03, 2013 8:52 am
The ECU is held in with a couple of wood screws and fixed in solid as long as you don't pull on it.
The injector pipes are also around 500mm long so that they can reach the inlet manifold on the other side of the engine.
PostPosted: Mon Jan 20, 2014 9:00 pm
Seen this at the wreckers, talk about getting it done drive in drive out...no thought put into this at all!
Users browsing this forum: Bing [Bot] and 4 guests
