 Post subject: Bexpro
PostPosted: Mon Oct 24, 2016 8:51 pm
Has anyone used Bexpro lpg software ? ive gone and bought the software to keep my car running at peak performance and to save on going to a LPG pro, obviously ive got no experience in LPG.
I serviced my Prins VSI system the other day (changed the filters) but not sure what i can do with the software except the auto calibration, does anyone have any advice on using the software ? :?:
 Post subject: Re: Bexpro
PostPosted: Mon Oct 24, 2016 10:11 pm
Try a search for Bexprins on here - theres a quite long thread covering someone trying to recover their system after messing it up using it. Though to be fair you can achieve similar results by playing with any of the correct software for any of the other systems available. I'd personally avoid both Prins and BRC if your inclined to the DIY route as they can both have pitfalls for non-installers (difficulty of getting the software and parts), though if you've already got it then its a bit late for that.
Is it just servicing as in maintenance to try and avoid problems, or are you trying to fix a problem that already exists? Running the auto calibration on a working system isn't a great idea, especially if you can't easily put it back the way it was before you started messing with it,. this is generally possible with the manufacturers software, might not be with 3rd party software or may not work 100% correctly if its possible. Its also unlikely to fix a problem thats actually present though it might mask it for a bit.
PostPosted: Tue Oct 25, 2016 10:30 am
There's more than one thread. I don't remember anyone that didn't completely screw their system up by using the Bexprins software. I think they all had to find a Prins installer to get it put right again.
PostPosted: Tue Oct 25, 2016 11:38 am
All good advice above. As I read it your car runs OK but you fancy seeing if you can tune it just a bit better? Chances are there are no potential gains from attempts to make it just a bit better, particularly not in normal driving (when foot isn't to the floor). If your system is working OK don't mess with any software settings and don't run auto-calibration, or you may need to visit an installer like myself to fix a problem of your own making.. In fact - go on have a play! :lol: :lol:
