PostPosted: Sun Jan 30, 2011 11:58 am
Hi I'm new to LPG I have a 54 plate laguna I brought I cheap because it was misfiring so I changed the plugs and coil pack it made a little difference but not alot it's a nlp LPG system With a icom 80 l tank when idling and driving if I turn the steering or put lights ect it drops revs it has no power to Ito can on a long run get 50 mph out of it but it takes it's time to build up to it when I clutch it it will stall any suggestions welcome I'm thinking possibly injector problem
PostPosted: Wed Feb 02, 2011 12:57 pm
The cutting out when turning the steering is probably an existing fault that is more noticeable because the LPG system is not in tune.
The power steering system should have pressure switch connected to the cars ecu the speeds up the idle as the steering is turned --- try cleaning the idle speed control valve.
"My friend: There's no safer investment than property in Pompeii."
