 Post subject: LDV LPG REG O3
PostPosted: Mon Oct 26, 2009 8:11 pm
HELP ME IF U CAN I PURCHASED A LDV LPG O3 REG, WHEN I PRESSED THE LPG SWICH IT WOULD NOT LIGHT UP BUT FOUND OUT THE WIRING WAS SHORTING AND BLOWING A FUSE,NOW THE LPG DISPLAY IS LIGHTING UP BUT IT IS SHOWING RED FOR EMPTY I TRYED TO FILL UP WITH GAS AND IT TOOK 84 PENCE WHEN U TURN IT U CAN HEAR THE PUMP CLICKING ON, BUT IT ONLY RUN ON PETROL I AM TOLD THAN IT IS METANO ONE SYSTEM IS THERE anyone have manuls or wiring diagrams . thanks rossko
P S I TOLD U ABOUT THE DISPLAY LIGHTING BUT I FORGOT TO SAY THAT THE WEE GAS BOTTLE DOES NOT LIGHT UP, LIKE THE REST OF THE DISPLAY ANY IDEAS BIG SYD[[b[
 Post subject:
PostPosted: Tue Oct 27, 2009 1:19 am
Most LDV have a liquid injection system (Metatron).
Usual failure is seizure of in-tank pump.
The click from the valve does not mean the pump is working.
If you listen at the tank when someone keys the ignition on you should hear it whirr for a few seconds.
Silence = may be beyond hope (pumps are next to impossible to obtain)
 Post subject: Re: LDV LPG REG O3
PostPosted: Fri Oct 30, 2009 9:34 pm
"]HELP ME IF U CAN I PURCHASED A LDV LPG O3 REG
P S I TOLD U ABOUT THE DISPLAY LIGHTING UP BUT I FORGOT TO SAY THAT THE WEE GAS BOTTLE DOES NOT LIGHT UP, LIKE THE REST OF THE DISPLAY ANY IDEAS BIG SYD
 Post subject: re pumps.
PostPosted: Mon Nov 02, 2009 7:50 am
Pumps can be obtained without any problems. You just need to know where to get them from.
