PostPosted: Thu Feb 07, 2013 6:50 pm
Not a car you convert or even see everyday so I thought I would share this one with everyone. Some of the photos did not save on my camera but most have come out ok. Not the first Hybrid through the classicswede workshops but the first of this type.
Front veiw
Hybrid
Tank primed and then undersealed
Colour coded filler rear mounted
Change over switch mounted in spare switch blank
Vapouriser mounted behind the engine (no space in any other place)
Very little room for water hose connnection
Injector rail mounted
ECU mounted under front scuttle
Power taken from main 12 volt connection
Engine bay after refitting scuttle and air filter assembly
LPG filter moved forward for ease of maintenance
Dai for any info feel free to email me dai@classicswede.com
PostPosted: Fri Feb 15, 2013 6:30 pm
Nice, what make of kit is that?
PostPosted: Fri Feb 15, 2013 8:05 pm
You can just about make out on the ECU it is a Europegas SAS system.
