PostPosted: Mon Apr 01, 2013 9:39 am
anyone shed any light on this little problem , vehicle is a 4.6 p38 range rover 2001 running prins multi point sequential injection . now problem is on cold start up the system auto switches to lpg [ after warm up stage ] as normal most of the time but maybe twice a week instead of switching over to lpg it stays on petrol and you have to switch it over manually , which isnt to much of a problem but better if i didnt have to
vehicle had a gas service november 2012 and does around 120 miles per week , has anyone got any ideas ?
PostPosted: Mon Apr 01, 2013 11:49 am
Images: 5
Normally the only way the system will revert to pertol only mode is if
A,the switch has been pressed before switch off
B,battery disconect or flat battery.
hth Woody
PostPosted: Mon Apr 01, 2013 5:14 pm
yes , or run out of gas but none of these are the case , so still scratching my head
PostPosted: Mon Apr 01, 2013 7:04 pm
Images: 5
try checking the fuses,if they are lose in the holder that may cause your problem.
woody
PostPosted: Mon Apr 01, 2013 8:41 pm
i will give it a look and report back
