LPG Discussion Forum
http://lpgforum.co.uk/
E gas spare parts
http://lpgforum.co.uk/viewtopic.php?f=29&t=14074
Author:  classicswede [ Wed Apr 20, 2016 12:20 pm ]
Post subject:  E gas spare parts
I have the following egas parts available removed from a non runner
4 cylinder ecu
Map sensor
Switch
Matrix injectors, resistance test is ok
The owner said the system ran fine before the head gasket failed. Parts sold as seen with no warranty as I was not able to test them. Wiring loom is there but only the plugs are salvageable.
£50 including delivery for the lot but may split. The injectors should be worth the asking price alone.
Author:  LPGC [ Tue May 24, 2016 10:11 pm ]
Post subject:  Re: E gas spare parts
I bought your last lot of injectors you sold on here and they worked well mate!
Which type of Matrix injector are these?
I also have an Egas reducer (which Gilbert never confirmed he wanted or could have had for nowt) and map sensor.. I sold the working ECU and switch to a German many months ago for about the same price as you're asking for a full system.. You might get more for that lot!
Author:  Just fix it [ Wed Apr 18, 2018 6:31 pm ]
Do you by any chance still have the egas ecu. Do you know if the egas 8 cylinder ecu will programme as a 4 cylinder ?
John
Page 1 of 1 All times are UTC
https://www.phpbb.com/
