 Post subject: E gas spare parts
PostPosted: Wed Apr 20, 2016 12:20 pm
I have the following egas parts available removed from a non runner
4 cylinder ecu
Map sensor
Matrix injectors, resistance test is ok
The owner said the system ran fine before the head gasket failed. Parts sold as seen with no warranty as I was not able to test them. Wiring loom is there but only the plugs are salvageable.
£50 including delivery for the lot but may split. The injectors should be worth the asking price alone.
 Post subject: Re: E gas spare parts
PostPosted: Tue May 24, 2016 10:11 pm
I bought your last lot of injectors you sold on here and they worked well mate!
Which type of Matrix injector are these?
I also have an Egas reducer (which Gilbert never confirmed he wanted or could have had for nowt) and map sensor.. I sold the working ECU and switch to a German many months ago for about the same price as you're asking for a full system.. You might get more for that lot!
