 Post subject: Wanted Toroidal LPG Tank
PostPosted: Sat Mar 12, 2016 1:06 pm
Hi All,
Has anyone got a 670 x 300 Toroidal LPG tank for sale which must be in date ideally a 4 hole with Multivalve or if not single hole?
A 670 X 270 may be an option but only if it is very cheap as I want to maximise my capacity.
Cheers
Julian
PostPosted: Sat Mar 12, 2016 7:11 pm
Just in case - 4 Hole tanks don't use multi-valves, they have a separate valve for each purpose (filling, over-pressure relief, gauge/sender, outlet). Single hole tanks use multivalves. If single hole you need to choose between 0 degree (usually but not always external tanks) or 30 degree (usually but not always internal tanks) multivalve mounting.
PostPosted: Mon Mar 14, 2016 10:37 pm
I have a multihole torroidal tank spare. Don't know much more about it. It was removed from my car on purchase when I changed to a cylindrical tank. Located in Gloucester.
PostPosted: Tue Mar 15, 2016 8:13 am
Have you got the dimensions and the date stamp?
Cheers
Julian
PostPosted: Mon Mar 28, 2016 7:45 pm
Just seen this. If you still want one, I can check it out in the next day or so. PM or Email me direct ideally, via my website http://www.classicmicrocars.com
PostPosted: Wed Aug 10, 2016 11:40 pm
I have a 720 diameter x 270 deep single hole full toroidal tank (95L water capacity) with multivalve, located West Suffolk, still half full of gas so about 35L - make me an offer!
Will check the date stamp but fairly sure it's in date/under ten years old although i've heard it's now done ona general condition rather than purely date basis for inspection purposes. Photos to come later if you're interested.
Dave
PostPosted: Thu Aug 11, 2016 11:19 am
I'd be interested in seeing pics Dave, could be interested in buying, only dunno how we'd arrange shifting it.
PostPosted: Wed Aug 17, 2016 11:43 pm
I'll get some pics tomorrow Simon - i've been "cyber-marooned" for nearly a week with no internet/phone thanks to a screw up by BT Openwide in the local exchange and only got back into the land of the living today so only just seen your post.
I would describe it as an "external" tank, 4 lugs/bolt-holes at the top and the multivalve located at the bottom of the tank on the outside edge on the "corner" of the sidewall and tread if it was a tyre. Odd description i know but i think you'll get the tyre analogy! :wink: :D
Dave
PostPosted: Thu Aug 18, 2016 10:40 am
Yeh, it'll be a full toroidal zero degree tank mate, what's the condition like and can you see a date stamped on the tank plate?
PostPosted: Thu Aug 18, 2016 6:49 pm
I'll let the pics do the talking but it appears to be pretty good :
You'll have to turn your monitor on its side (or your head!) for the last two as for some unknown reason the phone turned them 90 degrees after taking them "normally".
Dave
PostPosted: Mon Aug 22, 2016 11:16 pm
My tank is now listed on ebay :
http://www.ebay.co.uk/itm/282145913995? ... 1558.l2649
Dave
