PostPosted: Sun Mar 29, 2015 11:56 am
I have just bought a used Prins ECM VSI-8 system to go in my MG ZS180. It was removed from another same age MG ZS180 but the chap who removed it didn't label the electrical connections as he had intended fitting it into his own car.
Does anyone have the original instalation instructions or even wiring colours so I can check it through.
Also though it should be tuned resonably closely to the car it would be nice to check it out, does anyone have the softwear disc?
The car is a 2004 MG ZS 180 2.5, I'm not sure of the date of the LPG system but as the tank is a 2006 I guess it is a similar age.
PostPosted: Sun Mar 29, 2015 1:22 pm
I've got an installation manual that I can email you if you give me an email address. Software is a bit more of a problem as it is only made available to Prins approved installers. There's the Bexprins stuff that is supposed to work with it but the only time it's ever been mentioned on here is when people have used it and screwed up their system so probably best avoided.
PostPosted: Sun Mar 29, 2015 3:38 pm
Thanks mate, I've pmailed you a email address.
TBH I'm not so worried about the softwear as I'll proberbly get one of you pro's to give it the once over once installed.
PostPosted: Sun Mar 29, 2015 6:11 pm
I'm no pro, not at LPG anyway, just a bloke who has been running on it for the last 10 years or so and wouldn't use anything else. Whenever I find a manual or software, I keep a copy in case someone needs it one day. I did actually try building a website so people could see what I've got and download what they need but failed dismally......
PostPosted: Sun Mar 29, 2015 8:51 pm
I can tune it no probs...
PostPosted: Sun Mar 29, 2015 9:10 pm
Thanks Richard for the manual, exactly what I needed.
Thanks Simon, I shall let you know.
James
