 Post subject: 6mm injector nozzle
PostPosted: Sun Feb 01, 2015 12:36 pm
I am looking for an injector nozzle to fit on DN6 pipes, I only need the one as I seem to have damaged one on my V8 Disco but have no idea where to get one! It also should have a 2.5mm internal diameter, can anyone help?
 Post subject: Re: 6mm injector nozzle
PostPosted: Sun Feb 01, 2015 3:47 pm
Third item down http://www.tinleytech.co.uk/acatalog/Mu ... eral_.html
PostPosted: Sun Feb 01, 2015 7:43 pm
Yep, after reading the other post where it is explained a nozzle screwed into the manifold has cracked!
But in this case, are we sure it has a 2.5mm internal hole diameter (most manifold spuds have a bigger internal diameter)? The set should ideally be matched, in some cases this can be critical.
