LPG Discussion Forum
http://lpgforum.co.uk/
BRC 5 cylinder kit - from 2.5 volvo 850
http://lpgforum.co.uk/viewtopic.php?f=29&t=13489
Author:  classicswede [ Tue Sep 16, 2014 2:22 pm ]
Post subject:  BRC 5 cylinder kit - from 2.5 volvo 850
I have a fully working 5 cylinder BRC kit on a Volvo 850 complete with 4 hole tank.
The owner would like £300 and can deliver to UK mainland.
It is all still fitted to the car at the moment so if you wanted to remove it yourself that is still an option or I can remove the system for you.
Author:  LPGC [ Tue Sep 16, 2014 3:25 pm ]
Post subject:  Re: BRC 5 cylinder kit - from 2.5 volvo 850
Tank spec mate?
Looks like a Sequent56, has it got a Bosch type MAP sensor? Probably makes it a better prospect for someone to retrofit.
Author:  classicswede [ Tue Sep 16, 2014 9:14 pm ]
GZWM 630x250 59ltr
Author:  classicswede [ Sun Oct 19, 2014 10:49 am ]
BUMP
willing to take offers. This kit can be split if anyone is wanting the front end only.
Author:  jjsaul [ Mon Nov 03, 2014 11:36 am ]
Will this system fit a 2001 V70 (with the ME7 management system)?
I have had quite a few LPG cars over the years but my knowledge doesn't extend to exactly what systems you can use on which cars!
Author:  LPGC [ Mon Nov 03, 2014 11:46 am ]
In case Classicswede doesn't come on the forum and see your question pretty soon - I'll stick my neck out and say there's no reason it shouldn't.. The system came off a 5 cylinder Volvo 850. If you're interested you should call Dai at Classicswede, though. His number is at the bottom of all hi posts.
Author:  classicswede [ Mon Nov 03, 2014 11:35 pm ]
Yes the system will fit the P2 c/s/v70 series
The tank will also fit in the wheel well without any issues
Page 1 of 1 All times are UTC
https://www.phpbb.com/
