Clearing out some ods and end that I have knocking about. Some of the bits if no one wants them will end up in the bin.
R90, presume needs full rebuild assume not working
Zavoli injectors, were working fine when removed, includes loom to adapt to superseal plugs
Millennium condition unknown so assume not working
2 x AEB patch looms for petrol injectors. Allows engine to run with ECU disconnected
Star gas ECU condition unknown
switch
valtek/emmer vapour filter
BRC Genius 1500mb reducer - was working when removed
Valtek injectors for parts only
2x OMVL r90 for parts only
Romano vapouriser
BRC carb switch
Leonardo and aeb 426 not sure on condition
5/6 cyl pitagora was working when removed
Romano injection vapouriser was working when removed
Star gas switch
8 cylinder ecu
