PostPosted: Fri Dec 02, 2011 11:05 am
Guys,
I'm looking for LPG injectors for a Landi Renzo Omegas kit that has the Bosch plug ends for Med Injectors hence ideally Med Injectors would be desired i.e two rails of 3 injectors, otherwise let me know what you have as I'm sure I can probably cut the Bosch plug ends off and solder the on suitable plug ends depending on the injectors.
Cheers
