Post new topic Reply to topic  [ 1 post ]
PostPosted: Mon Oct 31, 2011 9:16 pm
AEB ecu originally pruchased to replace the one on my omvl xxie / xxin system, however it turned out the ecu wasnt at fault after all in the car! The ecu had been plugged in for less than 5 mins and never even programmed so literally as new.
It is for a 4 cylinder car and i believe it can also be used with some Bigas systems etc but please check as AEB made these and omvl etc simply bought them and badged them with own name!
I can supply info on back if required.
This is not the EOBD verson ( wiht the lambada feed)
Cost me nearly £180
Asking £150 ono.
