PostPosted: Fri Aug 12, 2016 10:05 pm
hiya, i have purchased and rebuilt engine on my astra g with the koltec gsi lpg system on, I have a 1.6 z16se 2001 with the lpg on and have 2 empty plugs and need to know where they go, I cant see anything for them to go into, one is 8 pin and 1 is 10 pin but the gas system will not switch with code 12 and 22 now engine rotation and low tps signal and I think its because something is missing out of these plugs. if any1 has 1 or knows the system to take a picture or explain what goes into it or to trace the missing wiring so I can make it up that would be great. If I activate the relay I've got gas right up to the injectors I would be very gratefull. I cannot find a schematic on the net that matches the system to make th wiring up myself. This is the plugs
Many thanks if any1 can help
PostPosted: Sun Aug 14, 2016 7:30 pm
Images: 1
Can't suggest a lot, but code 12 you can ignore. There should be a cut through on the engine loom for TPS - both this and the rpm signal tap should trace to somewhere in the loom, so start with finding the connection to each and tracing where it actually goes.
Theres a good chance that the plugs are just from the loom themselves - It might be useful to check what the wire colours in the back of those plugs are if you can't find any other info - PJPJ had a load of info on the site linked in his signature, but I can't get it to load at present properly - its worth a look here if its working again (theres some schematics there from what i remember, the EGI ones aren't particually helpful, the GSI ones slightly better).
http://homepage.ntlworld.com/paul.joyce53/bin/LPG/Vauxhall%20Koltec%20Necam%20System.html
Based on what i can see from the pictures I'd suspect one of those is the injector cut circuit as well (there isn't that many wires in the system to start with - 18 would sound like most of them to me) - Have you swapped the engine complete with the loom, or removed your engine and done repairs to it?
PostPosted: Sun Aug 14, 2016 9:22 pm
Hiya Brian_h thanks for your reply. I get the code 12 even with engine running that's why I suspect an rpm or cam signal. I've been trying to get that page to load for over a week now, I fear it's gone. I've just rebuilt the head and put a new set of rings on so only disconnected the nessesary and all gone back in same place. I bought the car needing the work done but don't know if the engines been changed or not.
PostPosted: Sun Aug 14, 2016 10:53 pm
Images: 1
Code 12 is normal ignore it. The other one is going to be your problem. I've got that page saved I'll try and dig it out for you tomorrow.
PostPosted: Mon Aug 15, 2016 7:33 pm
I dont think these are 'cut into the loom'.
Was this LPG from new?
Is it logging a fault in petrol OBD?
PostPosted: Mon Aug 15, 2016 9:24 pm
Images: 1
Found the file i was looking for with the codes in - its 2b4f58d84237d173_gsifailurecodes from that link i've sent to you via pm.
Code 12 is a start of codes signal - not an error code (you may be looking at the EGI codes rather than GSI)
Code 22 is your relevent one - the tps signal. The EGI system intercepts this so I'd have a look at the connections there and see if anythings amiss there first.
Has it ever worked on lpg in the time you've had it?
PostPosted: Wed Aug 17, 2016 9:29 pm
thanks for the info and the links, I'm gonna have a look through and see if theres anything that can help me, the gas has never worked, well say never I only got it 2 month ago and was just parked up for 5 weeks while I did the rings and the head but previous owner reakoned they used to use it before it was stood a while but you never know.
