 Post subject: Filter size
PostPosted: Tue Jul 14, 2015 8:08 pm
Need to order a new filter but not sure how they are sized :?
mine has a pipe dia 10mm internal 12mm external, i would
assume i need a 10mm, am i correct folks :?:
 Post subject: Re: Filter size
PostPosted: Wed Jul 15, 2015 7:30 pm
Yes it's all about the internal diameter of pipes mate.
PostPosted: Thu Jul 16, 2015 9:04 am
All depends what you mean by pipe. The rubber hoses are spec'd by bore, so a 10mm hose fits onto a filter can with 10mm outside diameter spigots. Outside diameter of filter spigots is what is specified.
PostPosted: Thu Jul 16, 2015 4:33 pm
Thanks guys looking at my own post it doesn't really make sense at all, had measured
the fittings on the filter which means i need a 12mm filter, cheers all.
