PostPosted: Wed Apr 22, 2015 7:46 am
I drained a LPG tank of a range rover 4 holes 92 liters.
Used some water to drain the tank.
I discovered slight rust inside after 1 year stockage.
I planned to mount it this week.
Do you think i can spray some rust inhibitor or some tank rust treatment to cure it? Or take it to a professional to treat it?
It is only slight rust inside. I can remove it with a small screwdriver from a valve opening.
Florent
Range Rover 4.6HSE 1997 GEMS with BRC Sequent 56
http://www.rr-evolution.com
PostPosted: Wed Apr 22, 2015 8:36 am
Light surface rust will not be a problem
PostPosted: Wed Apr 29, 2015 10:23 pm
I wouldn't apply any treatment - propane is an excellent solvent and will only strip it off anyway, possibly to clag something else up.
