Post new topic Reply to topic  [ 109 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6
PostPosted: Tue Nov 29, 2016 7:15 am
If I remember right Simon you made a comment about it been above the exhaust manifold.
PostPosted: Tue Nov 29, 2016 12:30 pm
Probably in one of my posts above but I don't remember and haven't re-read, you'll be right of course. Does it get hot, then? If related, it could be strange that it started to happen now in colder weather when it won't get as hot as in summer when you didn't have the problem. Or maybe if related it could be the contrast in temperatures that causes the problem. If related!
PostPosted: Tue Nov 29, 2016 6:39 pm
No you said it then you looked at it then you remapped it for me.
It was ok today. Still the car's on it's last legs so the gas will be removed soon away and I will get a new sensor for the next car.
PostPosted: Wed Nov 30, 2016 9:56 am
Ah, said it in person when you were here..
Still, might not be the sensor at fault.
PostPosted: Thu Dec 01, 2016 12:35 pm
I've check plug, live and earth to ecu and all good. What I haven't checked is the main plug on the ecu (it's not easy to get to).
Simon have sent you a text message about some prices.
Thanks.
I've checked the plug on the sensor, live and earth to ecu and all good. What I haven't checked is the main plug on the ecu (it's not easy to get to).
Thanks.
PostPosted: Thu Dec 01, 2016 7:41 pm
Hi Simon, I'll reply to your txt message in a PM on this forum, bit easier typing on laptop keyboard! Just finishing work.
PostPosted: Thu Dec 01, 2016 9:58 pm
Hi Simon,
Just checked no messages!
PostPosted: Fri Dec 02, 2016 5:06 pm
I hadn't sent the PM at the time, I have now..
Users browsing this forum: Bing [Bot] and 1 guest
