 Post subject: Brc flashing lights
PostPosted: Fri Sep 14, 2018 4:34 pm
Hi
I am sure this is a common problem but my Lexus RX fitted with a bra kit when the car starts all the lights are on for about 5 minutes then they all start flashing no matter how much is in the tank
Any help would be appreciated
Bob
 Post subject: Re: Brc flashing lights
PostPosted: Fri Sep 14, 2018 5:42 pm
Usually 1 duff level sender, 2 damaged (chaffed / broken / etc) wiring between ECU and level sender, 3 incorrect wiring to level sender or 4 incorrect gauge calibration in software. If the gauge ever worked properly most likely 1 or 2.
PostPosted: Mon Sep 17, 2018 5:12 pm
It has started working sometimes it just starts to flash after a couple of minutes and it may just work so will leave well alone
Thanks for your reply
PostPosted: Mon Sep 17, 2018 5:43 pm
No probs
