PostPosted: Mon Jan 05, 2015 7:01 pm
is there anyone around that does rolling road mapping on lpg, thought it might help my mpg a little bit
PostPosted: Mon Jan 05, 2015 7:17 pm
Might be of some help in the case of single point open loop systems but a rolling road isn't much use for setting up sequential systems..
The problem with rolling roads regards setting up sequential LPG systems up is that under bonnet temps can be very different compared to actual driving, and since LPG systems attempt to compensate for temp (but don't always do a good job of it), you can see the implications... I don't have a rolling road, but would in any case rather use the combined 'seat of the pants' and lambda technique than attempt to set flat out engine mixture on a rolling road.
Another point - If a sequential system is running anything like properly then under most circumstances it should be running closed loop - and running closed loop any minor calibration issues are compensated for completely. Since your critique is mpg, you won't be using the 'open loop high engine load' area of the fuel map often enough for any adjustment to this area of the fuel map to make a difference to the mpg that you're getting.
PostPosted: Sat Jan 10, 2015 5:07 pm
ok thats saved me some money then, another question is if the lean cruise was adjusted on the petrol system like on these economy fuel remaps people sometimes do would that then mirror over onto the lpg system.
PostPosted: Sun Jan 11, 2015 11:55 am
F1 in Bolton and Car Gas in Stoke do rolling road mapping.
The petrol ECU will be looking to achieve the same fuel mixture ratio on both fuels.
