PostPosted: Wed Jun 19, 2013 7:10 am
hi all,
i have big problem when setting my gasitaly f1 cng to my 4g92 engine.
first situation on petrol i setting 9 degree btdc my engine give me a good performance.
2nd situation on cng i need to set 12 degree btdc for good performance. but my engine knocking when on petrol.
my setting cng 700 rpm n below running petrol, after 4200rpm run petrol for overtaking.
now i setting 11 degree on cng engine running good but still have problem when have cool weather, on petrol knocking when high rpm.
any suggestion to fix this problem
thanks
PostPosted: Wed Jun 19, 2013 7:19 am
http://www.aeb.it/products/timing-advance-processors
PostPosted: Fri Jun 21, 2013 5:49 pm
thanks for that info. but i already ask their technical asst and result no timing advance processors suitable for my engine
any other solution
regard
PostPosted: Fri Jun 21, 2013 7:45 pm
How have you been adjusting the timing?
PostPosted: Sat Jun 22, 2013 5:39 am
adjust the distributor refer on timing light to set btdc. just a normal method to basic timing on efi system
PostPosted: Sun Jun 23, 2013 10:45 pm
If it has a distributor then it should be possible to use a advance processor.
PostPosted: Fri Nov 14, 2014 8:55 am
http://www.autogasitalia.it/db/prodotto ... ng&id=1778
how much cost and where i can by this timing advance processor..
Users browsing this forum: No registered users and 8 guests
