 Post subject: vapourizer adjustments
PostPosted: Sat Dec 03, 2011 9:00 pm
hi all anyone any info on vapourizer adjustments?
PostPosted: Sun Dec 04, 2011 7:00 am
Yeh I have a little bit of knowledge, are we talking single point reducers or gas injection? Single point units generally have a main mix screw and an air bleed screw. The air bleed screw is the idle. Generally on the top of the reducer or around that area(if they have been installed correctly). And the main mix screw is for main mix. However not all reducers have both. If you where a bit more specific then I may be able to answer what you need to know.
PostPosted: Sun Dec 04, 2011 7:59 am
its a koltec necam gsi system mate, after a bit of web trawling found this info on rebuilding and adjusting the vapouriser-
http://www.google.co.uk/url?sa=t&rct=j& ... 78oSh93tAg.
Its a PDF file so I couldn't add the info to this page.
PostPosted: Sun Dec 04, 2011 3:10 pm
Good guide , you managed to answer your own question.
PostPosted: Sun Dec 04, 2011 7:43 pm
doing that a bit on here lol. just need to find a supplier for a reconditioning kit as I've now got a spare vapouriser....
PostPosted: Sun Dec 04, 2011 8:24 pm
Autogas 2000 I believe.
