 Post subject: BRC valve function??
PostPosted: Wed Jul 27, 2011 5:18 pm
I've got a Stako 60 litre cylinder tank with an old style (no solonoid) outlet valve.
The gas tight cover lid exists and is says 'Turn clockwise to shut off' and points the the bottom right and left knurled nuts. However, undoing then about 2 turns does not seem to do anything and yes, it does have liquid gas in it, which I need to run through my engine (new installation using kit off identical car) so I can replace the valve with a new one and fit a new gas tight lid.
What am I doing wrong??
TIA....
Gareth
 Post subject: Re: BRC valve function??
PostPosted: Wed Jul 27, 2011 5:53 pm
You'll probably get more views in the General or Having Problems forums but what makes you think the tank has gas in it? The gauge is showing empty. The taps need to be fully undone too, not just a couple of turns.
PostPosted: Wed Jul 27, 2011 7:42 pm
Thanks for the tip, it has liquid sloshing around - not more than a few litres, but definitely liquid. I will try unscrewing further, but which one controls which? Diagonally opposite perhaps??
DOn't know why I posted it here MOD feel free to shift the lot somewhere more sensible. My only excuse if I've been working hard on a car ;-) (4 actually, aaarrgghh!!)
Gareth
PostPosted: Wed Jul 27, 2011 7:47 pm
The one on the left, next to the union marked 'Liquid In' controls the input and the one on the right, next to the union marked 'Liquid Out' controls the output......
PostPosted: Wed Jul 27, 2011 8:07 pm
Thanks, and not a problem to unscrew the nut as far as it will go?? - I don't want 5+ liters of LPG fountaining out of my boot!!
PostPosted: Wed Jul 27, 2011 9:06 pm
It probably wouldn't be a good idea to open the taps until you've got some pipes connected.....
But they are like a tap, they won't come right out.
PostPosted: Thu Jul 28, 2011 7:54 am
Thanks, yes, outlet pipe will be connected :shock:
Thanks for your input, very much appreciated :D
