 Post subject: Prins VSI system
PostPosted: Fri Jul 16, 2010 6:33 pm
I had to have the gas system disconnected to diagonise a problem with variable valve timing and now I have come to reconnect some of my wiring identification has come off , Can someone confirm what the In Inj 1 to 6 connect to is it to the injectors or the EMU from the car and where do the emulator connections go. I have all the colour sequences and cables are all marked I just want some confirmation before I start soldering!!
 Post subject: Re: Prins VSI system
PostPosted: Fri Jul 16, 2010 8:26 pm
You'll probably have more luck getting an answer by posting in the General Discussion or Having Problems topics. This one tends to get used for news about LPG so doesn't get many visitors.
PostPosted: Sat Jul 17, 2010 7:56 pm
Prins VSI have had wiring variations over the years, basically 'early' and 'current' types are different in the colours to the injectors and emulator(s).
So, whaddya got in the way of loose ends?
